bmtbandit
Pittsburgh, PA
Just so I have an idea of what this should cost. Can someone please tell me what the TORS and Cat bypass should roughly cost. I am thinking this is the way I am going to go. It is either the TORS or the Jardines. I want a good clean loud but not defining sound.
dougl
Reno, NV
2007 R3 Classic
Triumph sells the silencer upgrade, or cat bypass pipe, for $350 and the TOR's for $495.You can probably do better at a dealer.
The original Jardines were a bit louder. I've heard that the newer ones are more baffled.
Do you want 2 (Jardines) or 3 (TOR's) mufflers? That's a big concern for me.
You will need to get a PCIII and use their canned map for Jardines or have it custom mapped. Or buy the Tuneboy program.
Triumph provides a tune for the TOR/cat bypass but it is a bit lean and backfires on decel. Tuneboy wil take care of this.
bmtbandit
Pittsburgh, PA
Thanks, I really want to keep the 3 into 3 look. I think thats one thing that makes the Rocket look different. I know I need a Tuneboy, I want this to get the 1st three gears to have full power anyway. I just hope the TORs are throaty enough for my liking. I can't seem to find anyone in the area that has them on the ROcket. (Pittsburgh Pa btw)
9Ball
South Jersey
2007 Rocket 3 Standard
Mine were the list price $845 for both TOR and cat eliminator, installation and new tune included in this price. You can probably get them for 15 to 20% off dealer list and install them yourself for less money, but I had mine done prior to delivery. Not sure how you address the tune issue if you DIY.
dougl
Reno, NV
2007 R3 Classic
I think mine sound great - gnarly but not deafeningly loud. Put a K&N under the seat, get Tuneboy, and download this tune:
http://www.r3owners.net/attachment.php?attachmentid=41&d=1155692504
It's a slight modification (to eliminate popping on decel) of Wayne's 20050_2 tune for the TORs/cat bypass. You also need to turn off the O2 sensor in Tuneboy and physically disconnect it from th ECU.
HeR3tic
Heart of Dixie (Alabama)
bandit, installation of the bypass and I presume the Tors should be a cinch for you. there are wire mesh donnut like gaskets that will take a bit of finese to remove and replace.
On the suggested tune, I unchecked "O2 Sensor Fitted" but did not physically disconnect the sensor. I changed the values of the L1,l2,l3 tables as specified that dougl and Wayne worked up. I don't have any decel popping. And the ECM hasn't "relearned" any bad habits that I can detect.
dougl
Reno, NV
2007 R3 Classic
Interesting observation. There doesn't seem to be a reason to disconnect it physically if it was done in the software but that's what Wayne suggested.
I installed the PCIII O2 sensor bypass before Wayne's latest version.
bmtbandit
Pittsburgh, PA
Thanks for all the advice. I think I am going with the Tuneboy Route. I am going to call my dealer over the Winter and order a set. It sounds as if this is the best place to order from. With the Riding season here quickly diminishing :( I do not want to take time with tinkering when I could be rinding. Install it over the winter when it cold as **** and cant do anything else anyway.
Additionally I am assuming the underseat K&N just pops in. Or is there a lot of reworking involved in this.
