This is going to sound curt and not my intention
I can deal with curt, what I'd rather not waste time with is ineffective. Clear communication is clear communication, and as this is my... second? post, y'all don't know me from Adam and you're correct to second guess my abilities and methods.
Like I said above, I appreciate your time, everyone. Hobbies are a lot more fun w gurus to guide you.
The system was already failed originally - no real failure analysis done (with conclusive data) and no real data provided to say it WAS resolved with the replacement R/R (sorry again if this sounds harsh, but a generalization that says you believe it was north of 13 but less than 15 says you are just guessing at it - this is the only piece of 'data' you have offered or even checked in the course of these three different configurations)
A generalization is incorrect. What I said is that I "found that it was charging (somewhere north of 13v but south of 15v)". I tested voltage with it running after replacing the R/R, and found that the voltage was within spec. I remember THAT it was working correctly. The fact that I didn't write down the voltage does not mean I just
believe it was functioning. It was functioning, I tested it. I don't remember my cholesterol data from my last metabolic draw, but I remember my doctor told me I had nothing to worry about.
The system wasn't charging when I bought the bike in October, I tested the stator then, found it wasn't out of spec then, decided it was worth $20 to try an R/R, it showed up, I replaced the R/R, tested the voltage, it tested at a voltage that is appropriate for this bike (
I don't remember what the voltage is, but it was within spec), I took it for a ride, it died, I tested it and found it to read just under 12v while running, I found and fixed the problem with the Furukawa QLW connector, assumed that was the problem (because it was a grounding issue), replaced the R/R with another $20 used OEM unit,
assumed I had fixed the problem, drove it for 15 minutes, and when I brought it home it was not charging.
Your pointing out that I don't know if it was charging when I left is entirely correct, but again, Occam's razor says that the symptoms I am having with R/R #3 are caused by the same problem that killed R/R #2 (and #1), so from a troubleshooting perspective, there isn't a problem accepting that the R/Rs are dying as fact.
The fact that they ran for 15 mins, really suggests to me that they weren't EVER working properly and you were just draining your battery while riding - 15-30 mins is about average to discharge with a system that is not charging and running solely off battery.
Right, the frustrating part of this is: with the bike sitting, right after replacing the R/R (again, after installing R/R #2 for certain, and most likely also after installing R/R #3), the **** thing was charging correctly. I know it was. I tested it. It was working. Your statement being true and the system killing R/Rs are not mutually exclusive. Something is killing the R/Rs. Replace it, it charges, take it out around the block, it stops charging, replace it, it charges.
Your best way around this is to replace the connector and re-terminate onto the wires - you will need a proper crimp tool for those terminals to ensure you have an adequate connection (after crimping, I typically additionally solder the joint to be sure it indeed has a perfect connection - important to use a relatively high wattage iron however as these are big wires and terminals!)
Furukawa QLW Series Motorsport Connectors - Corsa Technic
You could choose to either just repair the OEM wire with new terminal, or make up a new 'ground' lead direct to the battery negative (you can also do the positive, but you would have to put a fuse-older in-line adding two more connection points you would have to ensure would be stellar)
But before I did any of that, I would once again check the stator as I described and be 100% sure you do not have a failure there.
Honestly, this is my strongest suspicion as to what your problem really is.
I will purchase new connectors and replace the ones I've got, the crimp and soldering will not be an issue, I've got wiring experience. I will also test the stator again.
I appreciate your time and expertise. It is frustrating to come in and say "Hey I did x y and z per the info on r3o" and sprinkled into the responses are "did you do x?" "are you sure you did x?" "how do we know you did x?" I own a $500 multimeter. I know how to check for isolation, and I know how to check voltage. I also understand that many,
many people do not do any sort of research on their own before asking for help. I am not one of those people. Your time is worth too much to me to f*cker you around. Just asking for the benefit of the doubt if you can give it.
Again, thanks a ton for your continued help, and I appreciate your communication skills (above where you preemptively pointed out that your response was going to sound curt). Forums are frustrating sometimes and overcommunicating helps a lot I've found.
Also - it's worth adding : Stator failure is pretty well documented on R3's - R/R's less so.
The R3 actually draws a fair amount of power esp if you run FAST. The faster you go the more sparks you need.
I run mostly on motorways at slightly excessive (legally) speed.
I had my system voltage drop consistently with both (then) Halogen Headlights on main beam and both 55W Halogen foglamps on when I got above 130kph (GPS).
- Below 130kph, fine.
- Switch off fogs (or lights - because I have a switch in there) , fine.
- Change all lighting to LED, fine.
So my guess is that on an R3 with accessories the shunts are actually not all that loaded. Which may explain why we see fewer R/R failure.
Also worth mentioning that earlier bikes with the CatBox get very hot near the stator which could exacerbate deterioration esp if you do a lot of slow traffic work. My catbox "fell off" officer.
I have just fitted an R3 similar Alternator to my old Guzzi - and the mfr is VERY VERY insistent about adequate cooling for the stator.
Eventually I'll be replacing everything with LEDs as well as going to the switching R/R upgrade, but for now it's clear that something ****y is happening.
My plan is to: retest the stator (with video, then have it notorized for DEcosse
lol), replace the QLW connector, run a new ground and hot from the connector, test the voltage while running (this will not charge at this point because again, I know the R/R is dying and I haven't replaced it again), note the voltage, replace the R/R, test voltage again, note the voltage, drive it around for a bit, hope the ****ing thing is still charging when I land back at home, and if it isn't, I'm not sure where to go after that: either replacing the stator or running new grounds to everything come to mind.
What are your thoughts?
Thanks again for your time errbody.
Alec
