Yes.. once you remove the radiator shroud, it's only 3 more bolts, although the bottom bolt is kind of a pain. You already have to drain the cooling system and oil. If you can drain these in clean containers, you can reuse them. The oil filter can stay on. I don't think you can get to the top bolts on the front engine cover with the radiator in place. If you can, it would be hard and still easier to remove the radiator. I just replaced my clutch plates/springs a few weeks ago.
