Within reason - long cables will cause voltage drop. The nominal max length is 5 meters (16 or so feet) for USB2. USB3 is shorter (as it's a faster connection, it's less robust.) You can get a repeater cable (that picks up the signal, amplifies it and passes it along) to go longer.
Here's a monoprice 32 foot active cable option:
You could also get a cheap Android tablet and an OTG cable for it; OTG stands for "on the go", ie a way to make Android devices able to act as a host for USB, which will make it possible to use your TuneECU cable with Android; TuneECU is available on the Play Store for something like $10.
