warp9.9
Pocałuj mnie w dupę
Yes you need to do ISCV reset after checking and or changing the TPS sensor. This sync's the tps unit both primary and secondary with the idle stepper motor position. I am betting your idle stepper zero throttle position is off a wee bit. And your bike being an 08 it might still have the older style tps in it.
Also it is a good idea to check and re-crimp the low voltage wires going to the coils (Two on each) they work loose after time but a pair of pliers can fix that.
