Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,797
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
Not sure if this has been done before. I put triple K&N's on several years ago. Also put on the little K&N behind the cylinders for the crankcase breather. I don't like that little basturd ! I retained my air box for storage so it's a real PITA to remove and clean. Also, over time the oil vapor collects on the back of the engine and starts to ooze out around the back. Not visible oil, just the mist which is just enough to collect dirt. That's why I like the "internal" combustion engine. Cause all the yucky stuff happens internally. (That came from a comedy skit where a gorgeous blond was explaining engines). So I tried something new (to me anyway). I put the s-curved hose back on that did go to the airbox. I swung it out some and connected it to a piece of 1/2" hose with a short pipe. I drilled a hole in the center K&N and connected the hose to it with a 90 deg. fitting. The K&N on the left has my air temp sensor in it. Voila ! No more PITA.
