A wonderful gift from New Zealand today!
ChicagoRocket
Saint Charles IL
2025 Triumph Rocket 3 R Storm
Look what I got in the mail today!!! Ooh baby. Installing now. Few questions.
1. Where does the little black piece and clamp go??
2. What size wrench do I need to pull the sensor off the exhaust?
So pumped.
All done! Beautiful system. Few questions.
1. Headers are slightly leaking, will that go away once the new copper gaskets heat up?
2. What do guys do with tors pipes since now there is no connection to the right side exhaust cover?
Thanks!
Thanks!
No, the headers and gaskets should fit perfectly without any leaks. Loosen everything back up and re-tighten evenly. Be sure the gaskets are seated and the flanges are perfectly parallel as you tighten them up. If a gasket got squished crooked you'll need to get a new one. Also, don't try to over torque the flange nuts in an effort to stop the leak. A stripped thread or broken stud would be a real pita.
The little black thing with the hose clamp is how you put your right side exhaust cover on.
