sleeves
Nitrous
Your header was a better fit then what I took off (stock). Saw no need for silicon. Did take my time with the torque wrench. Slowly tighten all three pipes evenly and did top bolts first then the bottom bolts. then went back and did a final torque check on top bolts. No silicon and no leaks.
What Sonny says
Ive had my pipes on and off numerous times, still have the original gaskets and have no leaks, just anneal them each time. Also make sure the headers are held parallel as you tighten up as they can fall in towards the motor, then you crush the gasket at an angle.
