warp9.9
Pocałuj mnie w dupę
Warp, didn't have any problems at all with clearances. From memory it is 380mm from the outside of throttle body no1 to no3 so the smaller unit will not fit, the larger unit is perfect as you can fit the air temp sensor between no1 and no2. I will take some more photos and post them so you can see what I have done.
Duncan
HMM interesting I have a set of throttle bodies here and they measure 11.5 inches from outside #1 to outside #3 thats 292.1mm so now I am confused as the 600 series is 435 mm long 17.125 inches. I will wait for you to double check when you take the photos if you would. Could it be you went with the 500 series instead of the 600 series?
