May tighten or loosen. If there is valve train wear the clearance will increase. If the head of the valve recedes into the seat, the clearance will decrease. That may be the more common case, but the factory specs and service intervals are probably the best spot to begin.
I have a couple of questions, How do you get the engine in position to check the valves? Do you rotate the engine using the bottom nut on the crank? and to adjust the valves do you have to remove the cam shafts to replace the shims?
Yes and yes cam cradle and cams must be removed unless you can lay your hands on special tool most dealers have that allows individual valves to be compressed so shim in bucket can be flicked out, good if only one or two needs adjusting, otherwise pluck the cams out and stick a set of nevs in :wink:
