Don’t know about logging. When you connect to your bike and turn on the engine, you’ll see more functions than you do when opening the program without connecting.
The main fuel tables (F) are based on throttle position (TP). The L tables are based on manifold pressure (MAP). The TP at which it switches to the F tables is only 4%! This makes it a lot less complicated to adjust the fueling. It’s still a pain in the butt because you need to turn the engine off after making changes, reload the edited map, then turn the engine back on to check it. Power Commander is much simpler, although there are tuners who do TuneECU.
