Clear service due wrench with TuneECU?
EskimoPie
Sahuarita, AZ
2021 Rocket 3 GT
Hey, can you use TuneECU to change the service interval and clear the wrench indicator from the dash or can that only be done via the dealertool? I fired up TuneECU and didn't see how to but a Google search implied it is possible.
Yes it's possible alright. I've seen posts on this site referring to it. However, I personally use a scan tool not TuneECU, so I'm no help other than I know TuneECU does do it.
To reset the service interval with TuneECU:
  1. Ensure you've set the time and date correctly in the bike's display.
  2. Connect TuneECU with the ignition on.
  3. From the "tables" page, swipe left to either the Dashboard or Adjustments page.
  4. From the menu in the upper-right corner (ECU?), select "Tests & Adjustments".
  5. From the "Test Devices" window, select "Adjustments" from the bottom-left corner.
  6. From the "Adjustments" window, select "Reset Service Interval" then select "Run" from the bottom-right corner.
  7. Select Km or Miles, set the desired updated service interval, then select "Validate" from the bottom-right corner.
There might be a step or two after that, but I didn't want to reset mine in the process.
