TxRIIIRider
Okay.. So I have my bike from the dealer. They loaded the TORs tune which sucked with the Jardines and was so lean I probably shouldn't have ridden it home.
I apparently don't know what I am doing when I load a tune, because the bike is now not idling again and running like crap and it doesn't make any difference what tune I load.
I need help.. Here's what I think I know.
Step 1 - Bring up TuneECU with your preferred tune on your laptop.
Step 2 - Remove the headlight fuse and connect bike to laptop with the OBD-II/USB cable
Step 3 - Allow TuneECU to discover the ECU and show all info.
Step 4 - If you want to load a new map.. "Download" the map to the ECU.
Step 5 - Once downloaded.. turn the ignition off, (replace headlight fuse at this point)then back on for 10 seconds, then back off.. and then back on.
Step 6 - Once TuneECU see's your bike's ECU.. Reset the TPS..
Step 7 - Start the bike and let it idle until is smooths out..
My problem, is the bike never smooths out and runs like crap no matter what I do..
This bike runs great when all is right, but right now, I'm just about sick of it..
