Tuneboy Modified Tunes
Pig9r
Kansas City, MO USA
20050 Tune modified
Rocket III Full power with catalyst
Secondary throttle fully open in all gears.
Full ignition advance in all gears.
Speedo corrected to remove 7% error from factory
  • 20050Tune_Modified.dat
SteveRed's 20050 Dyno Tune
This is a 20050 modified tune done on a dyno with SteveRed's bike by Wayne from TuneBoy..
Remap on all cylinders.
Secondary throttle fully open and full ignition in all gears
*Additional Notes* I went from 20054 tune to this tune and noticed a world of difference. More power, more responsive and smoother especially between 2000 and 3000 RPMs.
Here is a modified 20053 tune
Rocket III
Aftermarket pipe
With catalyst
Secondary throttle full open in all gears
Speedo error corrected to remove 7% factory error
  • 20053Tune_Modified.dat
This tune was made from the 20050SteveDynotune. I have maddogs, no cat, and undertank K&N. Temperature during testing was 90+ degrees F.
Speedo corrected
8% and 13% added
A/F correction made
  • Smoothdecel.dat
Here is a richer version of the smoothdecel tune.
Speedo corrected
10% and 15% added for decel
A/F corrections made
  • Smoothdecel2.dat
This tune is for PCIII users that want the extras Tuneboy offers. It is a stock Triumph 20050 map with secondaries fully opened, ignition restrictions removed in first and second gear and speedo corrected. Make sure 20050 was your base tune or otherwise your PCIII may not function properly.
Edit notes:
Secondaries Fully opened
Ignition remapped
Speedo Corrected
  • 20050TuneforPCIII.dat
kills the popping
Here is a variation of 20050TuneStaintune.dat I got from Wayne some time ago. He added fuel to the L tables to kill the popping and it works pretty well.
I guess here it isn't. The **** thing won't let me upload it. It's a 222k dat file. What gives?
Mod Note: It is fixed and attached.
  • 20050TuneStainTune_Decel1_Wayne.dat
Here is a variation of 20050_2, a tune Wayne put on his site for TOR/cat bypass, full power in all gears, corrected speedo. Basically, it's like the Staintune but specific for TOR/cat bypass.
Wayne fattened up the L2 table quite a bit to get rid of popping but it didn't work for me. So I copied the L1 and L3 tables from Wayne's tune in the last post had (20050TuneStainTune_Decel1_Wayne.dat) which he fattened up quite a bit, and put 620's in the 1st row of L2. This combo seems to work pretty well.
  • 20050DynoFinalMap_TOR_CatBypass_Decel.dat
This is the most recent dyno tune from Wayne. This is was done on a bike with the triple filter set up. It's listed as 20050_3 on the Tuneboy site. Wayne richened in the number 2 cylinder some and retarded the ignition also.
Edit Notes:
Triumph off road pipes and cat box eliminator
TuneBoy pod airfilters fitted under bear claw.
Dyno result was 158ftlb and 151hp
Uploading tunes as requested....
  • 20050DynoFinalMap_WithPods_And_IgnRetard.dat
