First performance mod...
Just purchased new in the box TOR silencers from a fellow member and have a couple questions.
Only performance changes I'll likely make are the silencers and eventually the cross over pipe. I like the look of the stock exhaust manifold so will likely never change that and no plans to change the air intake.
Anyway, when I called the dealer to get the TORs tune, I basically got a you won't like it speech. They said it would run lean and probably be a little rough, and I should expect pretty bad decel popping along with extra heat. I say B.S. there's gotta be a better way.
I have a 2013 roadster - blacked out with red stripes. I'm thinking I'll let them download the tune, then I'll add a custom map with TuneECU along PCV with autotune. Then if anything goes wrong, I can put it back to stock (tor tune) for warranty.
Done a lot of reading and still not sure about tune ECU working with my bike since it's a 13.
Any recommendations? Suggestions?
Thanks,
Gary
