Tripple K&N and IAS Help
Dennsell
Top Fuel
Kawasaki Japan (Perth WA) (GY - UK)
Bonnie T 100, unfortunately not Rocket lll Country
Can anyone advise what to do with the Air Temp Sensor when fitting Tripples..
Under the Tank or installed into thottle body or into a filter?
Whats the best solution guys ? :confused:
Mine is zip tied to the frame under the tank.
I figured that way it's out of the weather but still exposed to the ambient air temperature.
of course, it may get "some" heat from the head, but it still runs fine that way.
Not saying thats the best solution, but it's the one I went with and it works.
Stick it into the little filter and zip tie the filter as close to your triple filters as possible.
I've experimented with poking a hole in a filter and mounting the sensor inside. There is virtually no difference in intake air temperature with the sensor in the filter than with it sitting alongside.
I sat mine as close as possible between No 1 and No 2 airfilter ziptied to frame
