stand corrected !! I thought maybe just the bendix rod of the starter had to be changed I read somewhere that is what was to be replaced , but in fact it is the whole front assembly I presume as I look at the starters . also I checked the contacts found them corroded I think, "look at the pic what do you think"
so used s
ome fine sand paper and will put dielectric grease ,just a small film I also could not unscrew the front of the old starter my phillips screwdriver keeps popping out I will try a shop if not I will put the old starter back in I never felt the need for a stronger starter it is just that since it is all in the open I would upgrade to the 1.4 kw. will see if I can have the "head removed from the body "before returning the new one back to the store
