@warp9.9 Well I must let you know that I cleared the codes after reading an old post of yours on how to do it and everything is fine now.
I have the the black engine which does not show the oil as well sliver would.
Have ordered o-rings and will be here next week.
I did undo the two long bolts gave it a twist and did the bolts up. No joy think it got worse.
good to hear but you might and I say might have had better luck getting her to shift and settle in if you loosen the third bolt which goes to the head. but hey its nothing to take the throttle bodies up and off hang them from the handle bar throttle cables still hooked up and pull the tank.
Glad its working out as I just got my computer back up and running for how long? who knows I think its time to upgrade or work on finding a new fan motor I can try to install. You would think these buggers would last more then 12 years :)
12 years that's a good run for a confuser.
I have an old desktop I got back in 2000 did a complete reboot back to factory settings and not reconnected to internet.
You always could put a desk top fan and point it at the computer.
If it's a laptop you can buy a fan thing that you sit laptop on. I have one when my fan stop running about two years ago.
Come on you tight polish git --get rid of the old 386 and at least go with a pentium4:D
Got the oil tank off last night man did it have alot of oil in it.
I'm sure it has the wrong oring on it see attached pic
Should have drained the oil. The long plug front left drains the oil tank. The other two are the sump pan.
Lol pulled the wrong plug then.
Was feeling pretty crappy thought It was the middle plug for some reason.
Should of checked the manual.
Just gald I stayed around to watch as the two litre ice cream container was about 1.5 litres too small to catch all the oil.
Ordered o-rings a week ago and still not here.
