Check the injector plug on the harness it might have come off. Its got a lock wire you push before you take it off or put it on. It might not have latched. We need ti take care of this girst as no fuel means verry lean #2 cylinder. After you fiddle with the plug clear the code via tune ecu and the see if the fault happens again. It should thro the engine light on .
Ok but make sure you look at number two injector plug as that was the specific code you gave. P0201 is the #1 injector, p0202 is #2 and p0203 is #3 injector.
Read somewhere on an old post that you should check TPS and wouldn't you know it it's now sitting at 67. Dam sure it was at 62
And secondary up at 79 only rest that yesterday to 72.
So more a bit more to do before I get it running right.
I would advise buying yourself a good quality flexible drive screwdriver with interchangeable torxs and Allen heads . Invaluable for undoing throttle body and intake hose clamps !
Check the cable free play 2 to 3 mm pull cable at the throttle grip and most important did I say most important!!!!!! Return cable free play is checked down at the throttle body beyween the cable tube and the throttle wheel. You dont want the stepper motor fighting the cable and all the springs inbetween the first throttle body and the next two ket alone the primary tps.
It could make the idle oscillate making balancine and a stable tps setting a bugger .
It doesn't matter what the value of the reading is just that all 3 are within 10hPa of each other.
Made a tremendous difference when I did the stepper and voltage check. Easy enough to follow if you take your time. I believe there are some good guides on here re the subject.
