warp9.9
Pocałuj mnie w dupę
Bud you don't have to suck the oil out of the tank. The forward left drain plug is for the tank. The rear left goes into the  rear sump screen and the front right (kind of below the oil filter) goes into the front sump screen. As for which bolt hole on the tank it should only line up with one after the two main important bolts are snugged down. The little upper 6mm bolt goes into a rubber vibration damper bushing. While you are at it check the cam cover gasket especially on the oil tank side. If its leaking down the head are thru the spark plug weep holes it could make it look like the tank was leaking.  I'm not sure if you've had the cam cover up or not
I'll look at my bike for that bolt location when I get back from church.
