Rocket3Pilot
That type only fit on stock 1" bars don't they? I think you need to push the control switch gear up the bar to fit the BrakeAway Cruise control unit and then the hand grip. Unfortunately with extra wide T- bars they only leave enough 1" bar profile at the end for the switch gear and grip. I would have to return to the stock 1" bars to use that type.
That is same type as Go Cruise posted earlier - the Go Cruise has an adjustable tension screw as well.
So how does it release the throttle when you grab the brake? Looks like if anything it would add or twist more throttle on?
