barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
OK - so lets start by saying I normally do not use the R3 for commuting. I have a lot of heavy and sensitive gear that I sometimes (without notice) have to carry. I also discovered very early on that the wheelbase is simply too long to take the narrow twisty roads well. But my car is being repaired so needs must
My usual riding is FASTISH (120-140kph) CONSTANT SPEED. I can pretty much guaranty 220-230kms before reserve light. When @DEcosse introduced us the the Fuelbot - I bought one. Generally consumption is in the 7.5 - 7.8L/100kms.
The last tankful has been used exclusively to commute - 30kms each way - almost zero traffic seldom above 100kmh. Hit the reserve at 180kms and just short of 9L/100kms. That is approx 17% increase in consumption. I was surprised. I expected a difference but maybe 8.5L/100.
It's not to question anything - simply to point out the value of a decent fuel gauge when on "unknown" territory. Had I been somewhere unknown and banking on 220km range - hitting reserve at 180 not knowing where fuel is would be a concern.
A "comforting" plus from the 'bot - at reserve it says 25% of tank available. But that Distance To Empty display -
For inquiring minds - I run Hans V1 PCV AFR targets in 1st and 5th and V2 in 2nd,3rd and 4th. The ECU has a lightly adjusted (F/L switch and secondary flutterbies) TORS tune in. And yes - part of the equation IS because on the backroads I seldom get into 5th.
Next week I'll use the Guzzi - It's better suited.
