JohnnyCanuck
When I first bought the Stebel Horn some time ago I was stimied when I discovered that the left side cover and an evap canister under it and the Stebel would not fit.
Since then - I separated the plastic horn attachment from the metal canister to find new creative ways to fit the horn in a position where it is not noticeable. I would prefer to keep it out of the soon to be emptied airbox as I value that space for a proper tool kit and other miscellaneous items (perhaps a beer or 3).
I am planning on mounting the plastic horn section where the OEM horn is and was thinking of putting the metal can under the tank once I rip the guts out for the triples. Stebel states that the horn should be kept vertical within 15 degrees. I would have to lay the canister down horizontally. Has anyone attached the metal canister bit horizontally? Does it work? Any problems? Thanks!
