Stalling
vic
.040 Over
Triumph R3 Touring
Ugh :shock:
My bike started stalling ???
It never done that before, :?
I'll connect tuneboy in the morning, load a new tune in
Any advice, idea's ???
THANX
Vic
More details about the conditions under which this happens would help us in identifying a possible cause.
OK
Start bike, cuts out.... have keep the trottle a little open to keep it running.
When the bike is warm it idles badly, sounds like running on 2 cilinders.
The bike drives normaly, with just a little trottle added all returns to normal.
Vic
TPS sensor then maybe idle stepper motor. Also gheck the coils make sure nothing has came loose wires and such.
Connect your tuneboy and open the diagnostics then click the sensors button. Click the reset ISCV button. (ISCV = Idle Stepper Control Voltage) I did it with the bike not running (mainly because it would not idle) and when I started it she purred like a big cat. It was the only thing I tried and it worked so I quit experimenting. Your results may vary.
Hi,
Connected the tuneboy, reset the ISCV ....wait 15 sec said the software .... Start the beast... RRR,RRR,RRR,RRR,RRR,RRR :twisted: :twisted: :twisted:
Problem solved.
I'v no idea how this problem came to be? but it clearly originated in the ECU.
Thank you all for the tips and hail to the tuneboy 8)
