step1
Just been out to measure mine.Ive dropped the front 13mm and its an 05 model as measured from the top of the yoke to the top off the fork.I raised the front forks by taking the wheel and mudguard off then undoing the bolts that hiold the forks in place.You can apparently just undo the pinch bolts on the yokes and slide them up with everything in place.Thats how sully did his.Steers a lot better not so much counter steer.I also changed the fork springs to wilbers as well so aint to sure whether it was the springs or lowering it that improved it.I cant lower the forks anymore than this else i will run out of the larger diametre bit where they fix in the yokes.
