SH-87 with fan install in Roadster
leatal
Turbocharged
Dothan, Alabama
2014 Roadster, 2020 Rocket GT
Just finished my install of the series regulator and am real happy with results. Ran bike around town and the regulator stayed at ambient temperature. Let bike idle until radiator fan cut on and regulator was just slightly above ambient. I know, plenty of fins for cooling but works like a champ with virtually no heat from the regulator!
Just finished my install of the series regulator and am real happy with results. Ran bike around town and the regulator stayed at ambient temperature. Let bike idle until radiator fan cut on and regulator was just slightly above ambient. I know, plenty of fins for cooling but works like a champ with virtually no heat from the regulator! C04A6D4C-86A1-4C1D-AEFE-8BABEDFED4F2.jpeg 52B0A7C0-84D1-454A-97CE-DDC42E47E999.jpeg D02F7E0F-86E7-4238-805A-73A9C2169F1B.jpeg B7837557-7469-4D2F-9564-B2F4DBEE6465.jpeg
Pro install i really like that, could you post parts list? I could make mine alot better than what it is now very good job man
New harness like you did to positive with inline fuse, my terminal was loose on battery my first shakedown ride after getting bike back together and the fuse blew on that positive from r/r and you know what happened, luckily my batt drops to 10.5 and disconnects leaving at 10.5 until problem is rectified no pun intende. your settup is professional and i like professional
The red wire to the battery is actually the positive lead to the relay of my air horn compressor and Thunderbird horn. I am using stock wiring for regulator.
Parts list:
Coolerguys 80mm waterproof high flow fan- $15.95 (Amazon)
90x90x15mm aluminum heat sink- $9.99 (Amazon)
BCP 20mmx25m adhesive thermal conductive tape- $7.69 (Amazon)
Coolerguys manual controller- $5.95 (Coolerguys site)
.5" aluminum stock (Lowes)
2" aluminum stock (Lowes)
1" angle aluminum stock (Lowes)
2- 1.75" stainless worm clamps
4- 4mm stainless bolts with ss locknuts for fan (can't remember length)
2- 6mm ss bolts with washers and locknuts for regulator (can't remember length)
heat shrink for worm clamps and old inner tube for 2" bracket
Very good tip/idea, thanks.
I don't understand. Why is this needed and what does it do to improve the bike ?
well the sh-87 is better. this is a good place to put it, the case for it just class, show quality stuff, that fan because hes a perfectionist. you should do it, red oh my that will look good. Certainly you have a sh-87 right
The regulator is suppose to save wear and tear on the stator by reducing the electrical load thus reducing heat. Since I run LED headlights and running lights, the load is even reduced more. It also helps the oil in the engine run cooler and adds more horse power. Since the install, my water temp dropped 3-4 degrees (probably my imagination). The fan is probably not needed as the regulator runs quite cool. I have the fan installed to keep air moving over the regulator when bike is stationary and idling.
