Rocket wont start ???
i am guessing that you are hearing the starter solenoid
i am thinking that you are not getting enough voltage to the starter to crank the motor all the time.
check battery voltage while trying to start
like what was said battery needs to be tight.
or bad battery
how old is battery?
Good plan..I have a little device/tester that shows the draw down voltage when starting. It uses LEDs and the lowest voltage LED stays lit to show the voltage. It shouldn't go below 9 volts when cranking according to my tester. If it does, things are questionable.
Today i check relay ,and is oxid , i Will change relay 😎
Hi, new to the group.
I have had two rocket 3 BT’s, both had battery issues.
I had to call the RAC after not starting but lighting up the dash, after refuelling.
RAC took off the terminals, cleaned them, applied copper grease and never had an issue again.
Maybe I was lucky.
Hope this helps
Dave
