Hi All,
Just got the R3R back from Procycle Dyno. 159.41 HP @5700RPM and 163.94 Nm Torque @4500RPM
Same Pipes as Ponters Headers
K&N Tripples under Bearclaw
Neville Lush Tune sent to Fred @ Procycle to fine tune.
Got the Pipes through Nev and the filters from another member here.
Man have those pipes got some growl
But quiet enough to top gear doing 60 - 70 Kph.
Runs a bit rough down low and may even has a hicup rolling the throttle back on arround a corner at times
Fred mentioned something about a idle step motor (or something).
Rides different - just got to get used to it.........
Leaving Procycle dyno I broke traction while moving with out effort, I suspect cos the torque rolls on @2700 rpm.
Couple of things to finish off.....
- Clean excess silicone off the flange.
- install carbon fibre heat shield
- modify cover to rear foot peg
- Ride the socks off it
Might investigate a baffle??? and would like it to run smoother. Thoughts anyone
ALL COMMENTS WELCOME
View attachment Rocket Dyno.pdf
