Gerald
Turbocharged
Lou. Ky
05 Rocket III
For the lateral movement of the friction portion of the rotor across the buttons, there should be a few mm of play. There should be zero movement on the carrier portion, the middle part that's bolted to the wheel.
Typically the problem on free floating rotors is they get tight and stop moving at the button area, this usually leads to a pulsing at the lever/pedal, similar to a warped rotor.
I usually clean and spin the buttons/ bobbins every winter or two. My riding is probably less than 6,000 mi. a year.
Azisbest
Turbocharged
Arizona
2020 GT
Thanks a bunch for the info, even my dealer hasn’t been able to find it, unless they aren’’t really trying.
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
when i worked on tribals 2005 front rotors 200000+ they had a lot of play but did not give problems we replaced because the brake pads wore out the rotor
with him towing that trailer put a lot of wear on the system.
yes i know we are talking about a different set up but we are still talking about a floating system.
hth
Azisbest
Turbocharged
Arizona
2020 GT
hth
I appreciate all input.
Azisbest
Turbocharged
Arizona
2020 GT
Well I went ahead and ordered the new rotor and after it was installed I can say it has way less radial slop than before. You can hardly move the rotor now and before it probably had an 1/8” of slop in every direction. I dont know what the ramifications would have been if I had done nothing but I feel way more confident in the brakes now. Interestingly the bike had exactly 66,666 miles on the clock when I had them change the rotor at the dealership.
Gregger
Timmins, Ontario
2012 Rocket Roadster
If you check, I think you can purchase replacement floating brake rotor buttons. This might be a cheap solution if the buttons were the worn part causing the play. There are a number of videos showing how to replace.
Azisbest
Turbocharged
Arizona
2020 GT
that might have been a solution for sure, I dont discount that. I admit I am ignorant on floating rotors.
sunny
.060 Over
Rocket 3R LIMITED EDITION
has anyone figured out torque needed if we proceed with the replacement floating brake rotors button? or its just plug and play
