Okay here it goes. Please remember with respect to my install, radar detectors are legal in the provinces I ride so I did not try to hide the device, just the hardware I used to do the install.
After some thought I came up with the idea to use GOPRO mounting hardware that way when I remove the detector I can install my camera if I chose.
I purchased the Kuryakyn power outlet as I needed a cigaret lighter socket for the escort live power cable. I drilled a small hole in the windscreen mounting bracket to accommodate the GOPRO helmet extension bracket. Everything attached quite snug.
I went for a ride to test things out and so far I couldn't be more pleased. Very little vibration on the unit unless I hit the odd rough spot in the pavement but it had no effect on the detector. Now this detector is GPS enabled and it stores the location of all known red light and speed cameras( fixed location) the detector itself is plug and play, very easy to use. You will notice in the picture of the detectors power supply there is a warning light and a couple of buttons, one of which is a report button. This is the Escort Live power cable and it works with an app on your iPhone or android phone. You go into your phone settings and in the Bluetooth settings you pair your phone with the charger.
 As mentioned in earlier post about the only way you will beat a laser is to jam it, well there is another way...you need to know it's there in advance. As you drive, if you get a warning signal on the detector, you adjust your speed and as soon as you identify where the radar is located, hit the report button. What it does is marks the warning on the map within the app on your phone, it also alerts other drivers of the trap so that if they get close their detectors will alert them and visa versa. All that said this only works if your detector is Escort live enabled, some Bell detector have this option as well. I won't go int too much detail on it here as you can find loads of info on the net. Just look up escort live.
This is where the senna comes in. As the phone is paired with the detector, you get voice alerts through your phone. I still have some testing to do to ensure that all information the detector is producing is coming through the phone. I'll know for sure tomorrow as I'll be going on a longer ride.
