Stevepaff
Hi guys.
I'm pretty sure this is gonna be the tps but thought I'd run it by some more knowledgeable people.
A few weeks ago the bike stopped holding an idle very well. Everything seemed fine on tune Ecu apart from one throttlebody is a little lower than the other 2.
I have previously changed the map to a map that was written for the cat bypass pipe and the secondaries to 100%. I doubt that was it as its been running well on that map for over a year.
I reset the adaptive anyway and ran the 12 minute thing just for something easy to try. It seemed to work, at least until a few days ago.
I was coming to a stop and briefly for a few seconds the bike started to drop idle again, not enough to cut out and literally for a few seconds then sorted itself out.
Anyway yesterday while holding a steady throttle it started to have a couple little surges and pops. Gave the bike a little blast and it seemed to sort itself out. But today on the way to work it felt like the bike was pushing me even tho I was off the throttle, came to a stop and the idle was up at 2k. Then settled down and seemed to run fine but still felt like there were small surges going on. It did that a couple times but was fine when I rocked up at work.
Does this sound like a failing tps or something else.
Sorry for the long post but I figured if I wrote everything it would be easier for someone to give opinions or advice.
Cheers.
Cheers.
