No real insight. The pod filters seem much less restrictive than K&Ns but maybe not if the side of them contacting the inside of the bear claw is blocked.
Yes, I have a air temp sensor. Now I understand. But it seems german Rocket has a different sensor. My sensor is 16,5 mm wide and on the end 17,25. So I have to buy a filter which is smaller? Like this: http://www.knfilters.com/search/product.aspx?Prod=RU-3230 But this is only 16,0 mm wide and not 16,5. Are the flange insides made from soft rubber or is this the reason that you take a filter with diameter 19 mm? Because the next bigger size of K&N filter which I found is 19 mm.
I thought that I need the filter for the vent line of the engine. This is
behind the plastik cover (each side one cover with 2 bolts).
Somebody in this forum wrote that he put of the original air cleaner and
likes it to have a box under the seat to put something in.
But the original air filter is the filter for the vent line of the engine,
too. So if you left out the original filter, you need one more filter with inside diameter 13 mm or your vent line has no filter.
Jim1963 your correct about that. The crankcase must breathe or it will start pushing out gaskets.and leaking. They don't put out the presure or volume of say a harley so I just wired foam to the end of the hose to keep dirt out.Will pick up the little breather when I get a chance. I have noticed that most owners don't even know its there. Good catch. My air box Is now a drink cooler and if I diden't want oiley beers it should be disconected. Jack
