m6w6 .040 Over Joined Jun 8, 2017 Messages 77 Location Neufeld an der Leitha, Austria Ride 2009 Touring Jun 7, 2018 #1 Say a tuner does it with PCV, can the resulting table be applied with TuneECU? ... or would it be of no use?
Claviger Aspiring Student Joined Jul 25, 2014 Messages 6,934 Location Olympia Washington Ride '21 Z H2, '14 R3R, '02 Daytona 955i Jun 7, 2018 #2 It can be transferred over but it’s not quite as straight forward as it seems. The import PC map option in Tune ECU is questionable, at best.
barbagris Mad Scientist Joined Aug 1, 2010 Messages 12,988 Location On the verge of insanity Ride 1979 Guzzi V1000G5 - 2018 KTM 790 Duke Jun 7, 2018 #3 Claviger said: It can be transferred over but it’s not quite as straight forward as it seems. The import PC map option in Tune ECU is questionable, at best. Click to expand... Questionable like - has anybody actually managed it?
Claviger Aspiring Student Joined Jul 25, 2014 Messages 6,934 Location Olympia Washington Ride '21 Z H2, '14 R3R, '02 Daytona 955i Jun 7, 2018 #4 It does import the table but there are a ton of reasons it won’t transfer over as easy as two clicks and done.
barbagris Mad Scientist Joined Aug 1, 2010 Messages 12,988 Location On the verge of insanity Ride 1979 Guzzi V1000G5 - 2018 KTM 790 Duke Jun 7, 2018 #5 Claviger said: It does import the table but there are a ton of reasons it won’t transfer over as easy as two clicks and done. Click to expand... Mine just says the file is incompatible.
Neville Lush www.nevillelushracing.com Joined Feb 26, 2007 Messages 1,042 Location Victor Harbor South Australia Ride Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki Jun 7, 2018 #6 It is designed to work with PC 3 I believe.
Claviger Aspiring Student Joined Jul 25, 2014 Messages 6,934 Location Olympia Washington Ride '21 Z H2, '14 R3R, '02 Daytona 955i Jun 7, 2018 #7 As I understood it as well, a legacy function that hung around for fringe case use.
m6w6 .040 Over Joined Jun 8, 2017 Messages 77 Location Neufeld an der Leitha, Austria Ride 2009 Touring Jun 8, 2018 #8 Thanks guys, appreciated! one question, though, you all are using the windows version, aren't you? because AFAIK it has been unmaintained for quite some time. the Android version says "import PCIII/V table"...
Neville Lush www.nevillelushracing.com Joined Feb 26, 2007 Messages 1,042 Location Victor Harbor South Australia Ride Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki Jun 8, 2018 #9 I still use the windows version. Most of the Triumph ECUs have been unmaintained for a while as well. If it works ok I do not fu$k with it. That's just me I guess.
