Passenger footrest risers?
xlr8tion
Turbocharged
Aiken, South Carolina
2016 BMW S1000XR
Hey Guys.....
My Rivco passenger rests are about 3/8" from touching the top stock pipe on the R side....Does anyone of a set of adapters that move the footrests up and or away from the OEM pipe. Putting a D and D 3-2 exhaust would be a problem as they have a slight upward rake and I do not think they would clear the footrests....
Thanks!
Greg
I believe when you install the D&D pipes you will have a little more clearance because the outside diameter of the D&D pipes is a little smaller than the OEM pipes by 10 mm or more.
Thanks Bill....
I was more concerned about the upward angle of incidence.....The oem have less "Upward Cant" than the D and D's. Did you take a close look how close, in my pics, that the Rivcos come to the upper pipe/
Thanks....
G:)
From the looks of it you do not have the rivco relocation arms which also extend the floor boards forward and up a little bit. Don't let your passenger know or you will be buying them. :D
Look at this picture closely and you will see how much extra clearance room there is between the passenger peg mount and the D&D pipes. I think your Rivco boards will be fine. There looks to be a full inch or more of clearance. If that isn't enough to ease your worries then of course you can always get the Rivco Relocation Arms like I have.
Thanks Bill..you always come through! Looks like it would fit! You da' man again!
Warp...my wife if 5 foot tall so they are fine...
Cheers...G
I made a relocation bracket a few years back out of some 1/8" bar. It was not that difficult, even with my limited manufacturing abilities.
