Owwwwwww
Red with a silver motor would do that for sure.
Black motor probably not as much
following the Color Laws of Physics
Red & silver awfully slow,
Red & black not as slow
Black & silver pretty quick
Black & black extremely fast
Kamelion fastest in known universe.
I can handle this for Hanso. It's so obvious! The 82% throttle opening is only for red bikes. Imagine how they would humiliate the inferior black ones if they came with the full 100% from the factory?
Owwwwwww
Richard as you can see there are other wise men in this mad house, enter stage left ......"TO rocket" you just can't beat wisdom like that so as they say SUCK IT UP Skip and Mitch!!!!!
Well Bike wouldn't crank over at 5 am this morning wacked the charger on anshe started. So had to but a new battery found a Decca 500 crank amps ..$250 and a small C-Tek bike charger $50 including a handy quick plug lead, he fitted it free
Another problem bad misfire at 2000+ rpm... I know TPS Got home after riding in Heavy rain and lifted the tank to check TPS and Throttle travel .. well the thottle problem was a **** muti-connector only when the tank was down. Fixed also clean the C/angle sensor.
Tune ECU said TPS voltage was 4v so I pulled it ..and its Black so I reset it to 6v (7.1) so I am guessing a new TPS (blue) in next.. after being up early I am too rooted (tired) to give it a test its running and revs up so hopfully it will get me to the coal face tomorrow.. I will get a TPS on the way home if the local rip-off joint has one.
ED Yep, $206
Oh! the Joys of owning a 05 Rocket 3 ( I wouldn't be without it )
Owwwwwww
