Chris Kelley
Turbocharged
I suspected I needed to replace my tires and the shop just confirmed it so I have a few questions for those wiser than myself.
I've read other tire threads and I've seen lots of posts mixing Avon Cobra's in the Front and the Bridgestone Exedra's in the back and I thought I would go with this combo myself. However I've come across a deal for a front end Metz that's too good to pass up. So given that what little I've read indicates that mixing brands can lead to unexpected results on the tires, I was curious to know if anyone has run a Metz in the front and a Exedra or a Cobra in the rear? How did it work out?
I've also noticed that the Exedra appears to only be available in the 240/55R instead of the 50R. Is it possible to adjust the ABS for the tire size change? The manual indicates the ABS calculates the difference in the rotational speed of the front and rear wheels so a size change may lead to some wonkyness there. Or have others already determined that it's pretty much irrelevant?
