1olbull
Riding Motor Since 1950
Why cheap out ? Put on the Avons front and rear. Lower the front forks 10 millimeters. Handling is absolutely awesome.
Let's see:
If you lower the forks 10mm (.3937") with consideration to the 32° rake, you actually lower the front end .34 inch.
There is also NO correction to the speedo.
With the OEM tires, the rear axle is .5 inch lower than the front; therefor, the resultant is the rear axle remains .16 inch lower than the front.
With a rear Excedra Max 240/55, the rear axle lifts up .5 inch, resulting in the axles being level.
With a rear Excedra Max and a front 140/75, the front axle lowers .59 inch, resulting in the rear axle being .57 inch higher than the front.
Hope this makes some sense?
