franklarochesr
Lochbuie,colorado
2006 rocket 3
I've got tune eco for maps not sure wich to use
I have a 05 classic
Cat delete with high flow pipes
No other modes i know of what is the best tune to load in
I have a 05 classic
Do you have the Triumph Offroad mufflers (TOR's). If so, try this:
This tune your idle will be to low and will give you problems. The oil pressure will be low and mess up the motor.
Then raise the idle. The important thing in this tune is the added fueling, derestricting the secondaries, and added fuel in the L tables to reduce popping. The first Rocket tunes had lower idle. The Roadster idle table varies idle with engine temperature. At -15, 1500 rpm, at 17, 1018 rpm, at 38, 892 rpm, at 58, 850 rpm, and at 78, 850. rpm.
Pm me your email address I have a good tune from Hanso think will work for you. I have installed it on 3 rockets with 3 K&N filters. 2 are running good. Am doing the 12 minute tune right now on the 3rd bike. Will update later on the 3rd bike later :eek::p:roll: OH it's not my bike it's the Mexicans :p
He doesn't have K&N filters. The tune I posted was made by Wayne McDonald of Tuneboy on a dyno on a bike with the same exhaust and intake as Frank's. By the way, if Frank has a 2005 with an original tune in it and it idles OK with that, it will idle the same with the decel tune.
