Confused..com ......today I uploaded the CES with Ramair for the early Roadster but the map says 20352 which is the standard map?
Ok Chandelierman lets go through this one step at a time.
From the photograph you have the green flashing light in the bottom right hand corner. That is good. Your software, cable and computer combination is connecting correctly with the bike ECU.
Now in the top left hand corner we can see what is loaded into the bike ECU - you have the serial number, the map number and the checksum. As you have stated the map loaded on the bike is 20352. Now please remember that the bike ECU will only ever show you a number, it has limited capacity to hold data - therefore it can not show text information added by ourselves to help identify the different files.
All of the maps that you download from the forum resource area or the TuneECU web site will use a base map that has been tweaked by some of the venerable contributors to this site. Depending on which year and model of Rocket that you have will determine which base maps can be used.
In my case the latest base map for a 2006 Rocket 3 Classic is 20228. What this means is that when I download a HansO tweaked map for my model Rocket no matter which version or tweak I download, the bike ECU only recognizes the 20228 base map number. However when you look at the tables and parameters on the listed on the left hand side you can see the tweaks that have been added.
So lets look at your map.
you are showing the graphical view of the F1 table which has some high value lines going up to and above 16000 - which probably is not standard
If you look at the bottom right hand side parameter figures
your Rev limit is 6700
Your fan is 94C
Your speed limit is 299km/h
I am not sure what your standard figures should be but I would guess that these are not standard also.
Now we get to the slightly complicated bit.
Did you load the tweaked file into TuneECU before you connected up to the bike? if so the program will show you 2 sets of information - or this is what I have found. The graphical data and parameters will be linked to the tweaked file that I had recently viewed and the ECU info was linked to my bike ECU. This is where some confusion might be created. The software holds the last data from the last file that it opened. I think that this is what you are seeing.
However if you have gone to ECU tab and chosen Read Map (3rd choice down) this takes some time and is registered by a green row at the bottom of the screen (in the area that states you destination at the moment). Usually you get a prompt from the package stating if the Read was completed successfully or not. In this case you should now be showing the current map and parameters loaded on the bike ECU.
If you read all of the documentation and listen to the experts you should ALWAYS read your bike loaded map first and save before loading a new map and then downloading into the bike ECU.
Again in my case the program would not read the map on the bike but I downloaded the HansO tweaked map anyway - as I knew it was ok.
