hombre
Nitrous
- Joined
- Dec 31, 2006
- Messages
- 1,021
TTS is alive and well... Richard reports record monthly sales.
TTS has new pulleys available for the R3 crank and supercharger. The "optional" crank pulley is 140mm in diameter vs the "normal" 100mm crank pulley. This is used in conjunction with a 90mm pulley on the Rotrex blower (replacing the normal 70mm pulley).
The resulting drive ratio spins the blower another 10,000 RPM and produces 1.1 BAR boost at 7000 RPM. Richard estimates the additional boost should be good for another 30-40 RWHP, depending on cams and exhaust.
One drawback... you need to machine an extension for the oil filter to move it forward for crank pulley clearance.
