I think this started after I disconected the battery the first time. Every thing other than that works fine should I be concerned over it or should I see about getting it fixed
thats best way to put it I did not even notice it until I looked for it to happen. I can live with it as long as it remains like it is. I had to replace to speedo on my Ace about 5 times before I finally got rid of it
I would get it looked at. It could be signaling something else is going on. Could be a bad connection somewhere that gets better when moving. Did you change the battery bolts with zinc coated non conductive ones? That will give you a false positive.
I will call the shop first chance I get about it. It makes the sound of the sweeping though. I had it disconected to install the speakers every thing else is stock when it concerned the battery
i have the same problem and i have not disconnected the battery
contacted dealer and he said its no problem and will sort it out under warranty at next service
