need tune ... help choosing for TORs
craigmpak
I have a 2007 Classic with TORs and cat eliminator pipe. What tune do I use? Do I pick a decat tune or a tune without catalyst .... or are they the same thing? Do I pick from the Classic tune list or do I pick from the All VINs tune list or ....
I have successfully updated my ecu prior to the TORs and it worked great ... (had the cat bypass pipe) .... now I'm hoping to get a good tune installed so I'm ready to rock when the snow melts!
Is it just me or is the list of tunes confusing? Maybe time to streamline it?
Craig
IF all you've done is put TOR's on and got the cat eliminator pipe, then a Triumph TOR's tune will suffice.
Same thing.
either or, I just adjust mine till it ain't rich or lean.
you never said what you're using to modify your tune.
Are you just taking it to the Triumph dealer, if so,
then go with whichever tune they suggest, the TOR's with delete pipe tune.
IF you have your own electronic adjustment tool, tell us what it is,
so we can make further suggestions.
Craig[/QUOTE]
so many variables and tunes for about all now, why mess with it.
Thanks for the reply .... I'm using TuneECU for my programming.
I think I will start with the OEM tunes from Triumph and go from there.
Craig
try this one if you are still running std airbox filter
  • Power-TrippR3 TORS underseat decel.hex
