Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,957
- Location
- Ride
I bought a few bits and bobs bundled with a black fly screen for my 2010 R3R and am trying to ID some of them, fitment for which model and if it is a Triumph or aftermarket part. The clipseal bags have a dozen or so mounting bolts of various sizes.
- Chrome solo fender mount rack - no markings but appears to replace pillion seat? Found it listed here with JRock's help- RIVCO still in shock £125.83
http://www.customcruisers.com/conte...ph-rocket-3-iii-solo-rack-r-rivco-tr3010.html - Anyone know what the 3 cover plates under the chrome rear side fender guard trims are for? Paul Bryant did - Ahaa another RIVCO bit and they do bite hard - ouch! :£76.55
Triumph Rocket III Exhaust Flange Covers RIVCO TR3012
http://www.customcruisers.com/conte...t-iii-exhaust-flange-covers-rivco-tr3012.html - The rear side guard trims are for use w/o saddlebags aren't they? They are paper labeled with date stamps/codes 21-02-08 Q00013 on LHS one and 24-02-08 Q017 on RHS one. I didn't get any with my R3R as it came fitted with black (possibly sprayed) versions with the saddlebags fitted.
- The solid metal chromed unopened rear fender trim came with a fitting sheet (same as this http://www.nationalcycle.com/media/wysiwyg/pdf/ispl/10-110643-000.pdf ) and fitting screws for a US made 'National Cycle" 'Front of Front' and Rear of Front' guard and 'Rear of Rear' guard and I think this is part #70-710073-000 'Rear of Rear' guard so I think that is self explanatory. A heavy item! Ahaa! found it on sale US $80.96 - National Cycle Cast Rear Fender Tip - Triumph 2300 Rocket III (04-09), and here £61.32 Yowzers! http://www.customcruisers.com/contents/en-uk/p6689_triumph-rocket-iii-04-to-07-rear-fender-tip.html
- Are the red reflectors for Touring hard cases? They are unused self adhesive with 2 circular cutouts each on the back as if they fit over rivets, or bolt heads. The R3R is supposed to come with a single reflector fitted under the rear number plate and here in Oz, red ones are only allowed for rear facing fitment. Chris Kelly makes best case for a US fitment "... My R3R has reflectors that size and shape mounted just under the chrome rear fender side cover's on little dedicated plates."
