Power-Tripp
Turbocharged
The AFR table has little or nothing to do with the fueling outside of where the narrow band Lambda (O2) sensor operates. Above cruise throttle percentage (more than 6-8% TPS), changes to the AFR table do nothing to actually changing the mixture ratio.
For instance, at a constant 3500 rpm and 20% TPS load, changing the AFR table from 14.70 to 10.10 does nothing to the actual mixture ratio. Yet a 2% change in the fuel % trim table will cause a mixture change.
The fuel % trim table controls the F tables (TPS%). At low rpm and loads, where the L tables have priority, you need to adjust the L tables for mixture changes.
The F_L Switch table sets the change over point from MAP (L tables) to TPS% (F tables). This switch point can be rather abrupt. So abrupt in fact, that it can cause issues to smooth operation at the points where the change-over occurs. In the latest versions of TuneECU, the tables are set so that the numbers indicate roughly the TPS% point at which TPS takes over from MAP. In older versions, the numbers were a little bit harder to understand - a 24 actually was closer to 6% TPS.
L and F tables are used at all points. It is just that one has much higher priority under some conditions than under others.
For instance, at idle, if you change the fuel % trim table, it takes very large changes before you actually see a change in mixture. However, a small change in the L tables, will cause the same amount of change to the mixture ratio.
And at a constant 3500 rpm and 20% TPS, a 3% change to the L tables has almost no effect on the mixture ratio, but as soon as you roll on the throttle, the acceleration compensation will increase by about 3%.
If you use a wideband Lambda/AFR meter, watch for changes in ignition advance and cylinder heat that will play havoc with getting consistent results. Both of these alter the residual O2 in the exhaust gases, and this alters the reading from the wide band Lambda meter even when no changes to fueling have actually occurred.
I hope this helps.
I hope this helps.
