rash_powder
I got this sorted finally!
I found I had targets in the zero column of the PCV, so it was running stupid rich at idle. I changed that column and the 500rpm column to zeros as another map I had was. That didn’t actually completely cure the problem though.
I cleaned the crank position sensor and found the bottom of my oil pan to be disgusting. The sensor was not at all bad, four or five whiskers to wipe away. But that wasn’t really it either.
What I found to be the primary culprit was the gear position sensor. Mine seems to have been made from non-up stabilized plastic so it had turned grayish and brittle and the case was cracked. I have pics on my phone to post, but I’m posting from my phone right now and struggle with it at times. When I got the sensor out and gave it a twirl it felt like gravel! I blasted the hell out of it with contact cleaner and then drowned it with lubricant oil.
Test run successful!!
New sensor on order from Bike Bandit. We shall see how well things go from here.
Many thanks to laviger for all of his assistance in this!!
