Hunting for a bike lift that works
Go to "scratch-built air box"....
Trick, where did you find the triple intakes for the rocket? Those are great!
I made the airbox....couldn't find any triple filter setups that fit under the touring tank and looked ok, so I came up with my own. My most major problem was that, being long-legged my knee would hit the rear filter (or stack because that was what I originally wanted). Using the airbox I was able to move the filters ahead about 2" and it also solved the problem of zero clearance on the rear throttle body. I thought about the undertank filter, but ingesting all that hot air isn't exactly performance inducing....probably the stock filter is just as effective as the under-tank setup. I never got as far as checking to see if the clearance under tank on the touring is the same as other models. Anyway, if you need more info, check pics in my album and if you need more info use the string scratch-built air box, or I can send you some of my measurements if you are inclined to build one yourself.
