R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,437
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
How did you get the shaft back together..
Just followed the manual, nothing special.
After removing the circlip, collets etc as above..
Clamp damper in vice using wooden blocks, and 35mm deep black/impact socket (hex, not bi-hex) and a large breaker bar to remove nut on splined driveshaft end
Remove that bearing then with a hydraulic press
Old bearing removed... (open bearing but should be sealed for life type)
Use hydraulic press to press new sealed bearing on
Some medium strength threadlocker for putting the nut back on again
