hole diameter
lifts
Hi Skip, I should know tomorrow.
I am in Ontario at the moment and will be going to New York tomorrow morning for business related matters and will pick up the brackets at my U.S. address.
Thanks for asking and I will let you know.
Mac
Skip, it doesnt fit.
The holes in the R3 touring are much smaller.
I will take a look at it in the morning and see if its worthwhile drilling the holes bigger, But from the quick glance that I had tonite it looks like there may not be enough metal around the hole.
Let you know.
i had no problem with them fitting on my r3t or stb instead of drilling hole bigger take a grinder to the stud on the bracket till they fit maybe the holes on the 2010 models r smaller than the 08
My '08 standard had a very small hole on one side, it had to be drilled out for the Rivco center stand. The factory hole was (is) off center but drilled out with no problem large enough to accept the bolt.
Link Removed
As a footnote on the Rivco stand, they are more trouble than they are worth. I do enjoy mine but it drags a little before the floor boards on right turns, and it's difficult to get the bike up on it. A paddock stand is less money and less hassle.
