At first I thought Steels was the water pump, but it turned out to be the rear hose right in the back it had a stone get trapped between the clutch cover and the hose. Right in the arced area of the cover. Of course his was a OEM hose. I'm thinking Reds bike has the Samco hoses which should be stronger or I just wasted money on a set. Mine has what looks to be a stone hole also. But they're original 2007 hoses. I hope his turns out to be a hose problem. Look at it closely you might get lucky.
Thanks Warp. I tightened all hose clamps on my Samco hoses, cleaned off all the crud under there. Made a thorough inspection. I warmed up the engine and watched it drip out of the weep hole. No other leaks anywhere.
