HELP! Need Suggestions
Instead of using heat you can use a can of compressed air that will shrink the plug. But it sounds like the steel plug has galled with the alloy and more than likely will remove the thread from the sump when it is removed. I think a zinc based anti seize should be used with stainless steel in alloy cases. If you use the cold method sometimes tightening the plug slightly (before undoing) will help prevent the thread coming out.
I like this idea, I have several of those cans in the office. This is the main oil plug not either of the sump plugs. I will try this on the weekend.
